[postgis-devel] regex still missing?
nicklas.aven at jordogskog.no
Fri Sep 25 04:09:31 PDT 2009
Hallo
I haven't tried compiling with geography since ticket 250 was closed.
I still get the same error-message that regex.h is missing.
I see the include of regex.h is still in libgeom.h line 18.
Am I missing something in my installation?
or am I just missing something... :-)
Thanks
Nicklas
---------- Forwarded message ----------
Datum: 2009-09-15 19:00:31
Från: nicklas.aven at jordogskog.no
Till: Obe Regina
Ämne: Re: Just checking you can't compile PostGIS trunk either right
error here too: In file included from g_box.c:12:
libgeom.h:18:19: regex.h: No such file or directory
make[1]: *** [g_box.o] Error 1
make[1]: Leaving directory `/c/thesrc/pg15/liblwgeom'
make: *** [liblwgeom] Error 2 /Nicklas
2009-09-15 Obe Regina wrote:
I can't compile PostGIS trunk because Paul introduce regex dependency.
>Unfortunately downloading and installing the regex library gets me to
>linker and then breaks. Mark is looking into it.
>Just thought I'd ask in case you magically were able to in which case
>would like to know how your MingW install is different from mine.
>Thanks,
>Regina
>The substance of this message, including any attachments, may be
>confidential, legally privileged and/or exempt from disclosure
>pursuant to Massachusetts law. It is intended
>solely for the addressee. If you received this in error, please
>contact the sender and delete the material from any computer.
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20090925/5a70453e/attachment.html>
