[postgis-devel] [PostGIS] #253: Gist causes wrong result from ~=
trac at osgeo.org
Mon Sep 28 02:56:39 PDT 2009
Reporter: nicklas | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: postgis 1.5.0
Component: postgis | Version: 1.4.X
Keywords: |
Something seems to have happen between postgis 1.3 and 1.4 or postgresql
8.3 to 8.4.
I couldn't reproduce on 8.3 1.3, but on 8.4 both with trunk and realeased
1.4.0
When running this on the attached dataset:
select a.the_geom ~= b.the_geom from test a,test b where a.gid != b.gid
and a.the_geom ~= b.the_geom;
I get the little bit absurd answer:[[BR]]
1537;1553;f[[BR]]
1553;1537;f[[BR]]
so the answer from ~= is different when appearing in the select-part then
in the where-part
Without the index this doesn't happen. Then they are sorted away by the
where-part.
Also if I take away any of the other polygons of the set this fenomena
dissapears. My conclusion is this indicates that the gist-index is
involved when built on this particular dataset. The dataset was bigger
from the beginning but I tried to take away as much as possible still
preserving the error.
8.3 to 8.4.
1.4.0
/Nicklas
Ticket URL: <http://trac.osgeo.org/postgis/ticket/253>
