[postgis-devel] [PostGIS] #337: [wktraster] Write online documentation for WKT Raster
trac at osgeo.org
Fri Apr 2 12:27:34 PDT 2010
Reporter: pracine | Owner: pracine
Type: task | Status: assigned
Priority: high | Milestone: WKTRaster 0.1.6
Component: wktraster | Version: trunk
Resolution: | Keywords:
Comment (by robe):
Was thinking. Would you guys mind if I started creating an xml file of
the functions with examples similar to the PostGIS reference section. By
guys I mean WKT Raster folk as well as PostGIS PSC/Developers.
I was thinking of packaging this in with the trunk so it gets put as part
of the PostGIS 2.0.0 documentation, but keeping it as a separate file.
Something like wktraster_reference.xml and all the reference ids would be
prefixed with RT e.t. RT_ST_AsBinary. Then later on we can merge it in
with the rest of reference by like name. Having it follow right after the
regular PostGIS reference section for now. I think we have stuff here
that is already pretty useful. Just needs some polishing and more
exposure. It will be easier to stress test the functions if they are in
doc book format and also attract more attention if its part of the main
manual. Then have an accompanying raster_comments.sql (separate for now
since its not part of core).
Thoughts? If all are agreeable, I can start putting that together.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/337#comment:6>
