[postgis-devel] [PostGIS] #490: raster casts to geometry and box2d should be assignment not implicit?
trac at osgeo.org
Mon Apr 5 05:28:11 PDT 2010
Reporter: robe | Owner: pracine
Type: defect | Status: new
Priority: low | Milestone: WKTRaster 0.1.6
Component: wktraster | Version: trunk
Keywords: |
It appears I can do this:
SELECT ST_SRID(rast) As srid, ST_AsText(ST_Union(rast)) AS wktrast
FROM dummy_rast
GROUP BY ST_SRID(rast);
SELECT ST_SRID(rast) As srid, ST_Extent(rast) AS extrast
FROM dummy_rast
Which at first glance I thought was cool, but then realized its probably
not cool.
I'm still thinking about why this is bad. For geography we decided this
was bad because geography aren't cartesian coords so the answer is
technically wrong. In case of raster its not quite so clear. I guess I
think all non-trivial implicit casts are bad, but that's the database
purist in me talking.
So consider this just a flagging of questionable behavior. Not
necessarily that I am disagreeing with it.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/490>
