[postgis-devel] [PostGIS] #478: [wktraster] There seems to be an offset in ST_Envelope or ST_Box2D
trac at osgeo.org
Mon Apr 5 09:26:26 PDT 2010
Reporter: robe | Owner: pracine
Type: defect | Status: new
Priority: medium | Milestone: WKTRaster 0.1.6
Component: wktraster | Version: trunk
Resolution: | Keywords:
Comment (by jorgearevalo):
Ok, I suppose I need a plugin to load image files as datasets, because I
only can open shapefiles. Which plugin are you using? I'm following this:
http://sourceforge.net/apps/mediawiki/jump-
pilot/index.php?title=Plugins_for_OpenJUMP#II_-_Raster_Image_Plugins
Ticket URL: <http://trac.osgeo.org/postgis/ticket/478#comment:6>
