[postgis-devel] [PostGIS] #297: [wktraster] Implement ST_AsPolygon function for raster
PostGIS trac at osgeo.org
Sun Apr 11 12:49:11 PDT 2010
  Reporter:  mloskot    |       Owner:  jorgearevalo
      Type:  task       |      Status:  assigned
  Priority:  high       |   Milestone:  WKTRaster 0.1.6
 Component:  wktraster  |     Version:  trunk
Resolution:             |    Keywords:
Comment (by jorgearevalo):
 Replying to [comment:15 pracine]:
 > What is the purpose of the dummy function?
 Simply to have a function to compile when you don't specify --enable-
 development option. I thought in this option as a way to activate
 "experimental" or "under development" features. If you don't specify it,
 you have a function to compile (a needed function, actually), but a dummy
 function. For a short time.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/297#comment:17>
