[postgis-devel] [PostGIS] #495: [wktraster] Don't seem to be able to specify non- 0 skews in ST_SetGeoReference
trac at osgeo.org
Sun Apr 11 21:40:48 PDT 2010
ST_SetGeoReference
Reporter: robe | Owner: pracine
Type: defect | Status: new
Priority: medium | Milestone: WKTRaster 0.1.6
Component: wktraster | Version: trunk
Keywords: |
I assume the carriage returns in ST_SetGeoReference are optional since I
was able to do this
UPDATE dummy_rast
SET rast = ST_SetGeoReference(rast, '2 0 0 3 0.5 0.5','GDAL')
WHERE rid=1;
But if I try to do this:
UPDATE dummy_rast
SET rast = ST_SetGeoReference(rast, '2 -0.5 0 3 0.5 0.5','GDAL')
WHERE rid=1;
I get error:
st_setgeoreference requires a string with 6 floating point values.
I assume the skew/rotation is supposed to be in radians.
On another but related note:
I want to verify we are renaming ST_RotationX/Y to ST_SkewX/Y -- haven't
bothered documenting those since I figure they will change.
Pierre,
Also your final spec states the below -- I assume this is obsolete and
should be changed to ST_GeoReference, ST_SetGeoReference?
ST_ESRIWorldFile(raster) -> string
Return the georeference of the raster as a string representing the 6
doubles (separated by a carriage return) of an equivalent ESRI World File
. See.
ST_GDALGeoTransform(raster) -> string
doubles (separated by a carriage return) used by GDAL to georeference a
raster.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/495>
