[postgis-devel] Showing debug messages in a PostgreSQL C function
Jorge Arevalo
jorgearevalo at gis4free.org
Tue Apr 13 07:20:04 PDT 2010
Hello,
I've sent this message to PostgreSQL general list. So, I apologize if
is considered annoying.
I'm programming a C function that returns a set (PostgreSQL 8.4). The
function crash, and I'm trying to debug it. I've read:
http://www.postgresql.org/docs/8.4/interactive/xfunc-c.html
http://www.postgresql.org/docs/8.4/interactive/error-message-reporting.html
http://www.postgresql.org/docs/current/static/runtime-config-logging.html
but I can't see any of my log messages. I'm using lines like this:
ereport(WARNING,(errcode(ERRCODE_WARNING), errmsg("This is a warning
message")));
or even simpler
elog(WARNING, "This is a warning message");
I've changed the level from WARNING to ERROR, and it doesn't work. A
log file is created, and when I start the server, stop it, run a query... I can
see the messages logged by the server, but not my own messages, raised
with ereport or elog.
What's happening? This is the log part of my postgresql.conf
# ERROR REPORTING AND LOGGING
# - Where to Log -
log_destination = 'stderr' # Valid values are combinations of
# stderr, csvlog, syslog and eventlog,
# depending on platform. csvlog
# requires logging_collector to be on.
# This is used when logging to stderr:
logging_collector = on # Enable capturing of stderr and csvlog
# into log files. Required to be on for
# csvlogs.
# (change requires restart)
# These are only used if logging_collector is on:
log_directory = 'pg_log' # directory where log files are written,
# can be absolute or relative to PGDATA
log_filename = 'postgresql-%Y-%m-%d_%H%M%S.log' # log file name pattern,
# can include strftime() escapes
#log_truncate_on_rotation = off # If on, an existing log file of the
# same name as the new log file will be
# truncated rather than appended to.
# But such truncation only occurs on
# time-driven rotation, not on restarts
# or size-driven rotation. Default is
# off, meaning append to existing files
# in all cases.
log_rotation_age = 1d # Automatic rotation of logfiles will
# happen after that time. 0 disables.
log_rotation_size = 10MB # Automatic rotation of logfiles will
# happen after that much log output.
# 0 disables.
# These are relevant when logging to syslog:
#syslog_facility = 'LOCAL0'
#syslog_ident = 'postgres'
#silent_mode = off # Run server silently.
# DO NOT USE without syslog or
# logging_collector
# - When to Log -
#client_min_messages = notice # values in order of decreasing detail:
# debug5
# debug4
# debug3
# debug2
# debug1
# log
# notice
# warning
# error
log_min_messages = debug5 # values in order of decreasing detail:
# debug5
# debug4
# debug3
# debug2
# debug1
# info
# notice
# warning
# error
# log
# fatal
# panic
log_error_verbosity = verbose # terse, default, or verbose messages
log_min_error_statement = debug5 # values in order of decreasing detail:
# debug5
# debug4
# debug3
# debug2
# debug1
# info
# notice
# warning
# error
# log
# fatal
# panic (effectively off)
log_min_duration_statement = 0 # -1 is disabled, 0 logs all statements
# and their durations, > 0 logs only
# statements running at least this number
# of milliseconds
# - What to Log -
debug_print_parse = on
debug_print_rewritten = on
debug_print_plan = on
debug_pretty_print = on
#log_checkpoints = off
#log_connections = off
#log_disconnections = off
log_duration = on
#log_hostname = off
log_line_prefix = '%t ' # special values:
# %u = user name
# %d = database name
# %r = remote host and port
# %h = remote host
# %p = process ID
# %t = timestamp without milliseconds
# %m = timestamp with milliseconds
# %i = command tag
# %c = session ID
# %l = session line number
# %s = session start timestamp
# %v = virtual transaction ID
# %x = transaction ID (0 if none)
# %q = stop here in non-session
# processes
# e.g. '<%u%%%d> '
#log_lock_waits = off # log lock waits >= deadlock_timeout
log_statement = 'all' # none, ddl, mod, all
#log_temp_files = -1 # log temporary files equal or larger
# than the specified size in kilobytes;
# -1 disables, 0 logs all temp files
#log_timezone = unknown # actually, defaults to TZ environment
# setting
Thanks in advance, and best regards
Jorge
http://www.gis4free.org/blog
