[postgis-devel] [PostGIS] #505: [wktraster] DumpAsWKTPolygons uses PostgreSQL 8.4 default construct
trac at osgeo.org
Thu Apr 15 23:49:01 PDT 2010
Reporter: robe | Owner: pracine
Type: defect | Status: new
Priority: medium | Milestone: WKTRaster 0.1.6
Component: wktraster | Version: trunk
Keywords: |
Just tried install wktraster on 8.3 and couldn't because of the DEFAULT
used in DumpAsWKTPolygons
DumpAsWKTPolygons(raster,DEFAULT int )
This is a feature that was introduced in 8.4, so will prevent 8.3 users
from installing WKT Raster.
Note the current PostGIS 2.0 currently supports 8.3, but it is very likely
when we finally release we may drop support for 8.3. Since this isn't
currently working yet, and has equivalent 8.3 workaround seems a bit early
to be leaving 8.3 people out in the cold because of this.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/505>
