[postgis-devel] [PostGIS] #494: [wktraster] ST_DumpAsPolygons crashes under MingW compiled wktraster (gdal)
trac at osgeo.org
Fri Apr 16 16:54:18 PDT 2010
Reporter: robe | Owner: pracine
Type: defect | Status: new
Priority: medium | Milestone: WKTRaster 0.1.6
Component: wktraster | Version: trunk
Resolution: | Keywords:
Comment (by robe):
Pierre,
I left out one line of instructions I had done that I didn't think was
necessary, but perhaps it is. I left it out because it didn't work for me
without the --without-libtool so I assumed they were older instructions.
Perhaps you can give them a try and then put the without-libtool back to
see if it works.
In the GNUmakefile of GDAL --
I remarked out lines 4 to 7 and replacing ${GDAL_ROOT} with ./
So in the end I had
# GDAL_OBJ = $(GDAL_ROOT)/frmts/o/*.o \
# $(GDAL_ROOT)/gcore/*.o \
# $(GDAL_ROOT)/port/*.o \
# $(GDAL_ROOT)/alg/*.o
GDAL_OBJ = ./frmts/o/*.o \
./gcore/*.o \
./port/*.o \
./alg/*.o
It could also mean you have an old GDAL in your path somewhere and
wktraster is picking that version up instead of the new one.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/494#comment:3>
