[postgis-devel] [PostGIS] #498: [wktraster] Gdal export of some files gives blank image
trac at osgeo.org
Tue Apr 27 17:06:12 PDT 2010
Reporter: robe | Owner: jorgearevalo
Type: defect | Status: closed
Priority: medium | Milestone: WKTRaster 0.1.6
Component: wktraster | Version: trunk
Resolution: fixed | Keywords:
Changes (by jorgearevalo):
* status: new => closed
* resolution: => fixed
Comment:
Fixed in r5577. I've rewritten a lot of code of GDAL WKT Raster driver
(update your gdal library), because sometimes the raster properties
weren't properly read. On the other hand, it's not necessary to make
pixelsize y (from GDALGetGeoTransform) negative. This GDAL function takes
into account if is necessary to make it, and do make it. So, I deleted
this part from gdal2wktraster script.
I've tested the code with the following (attached) images:
$ gdal2wktraster.py -r stock_elephant.png -t gis_schema.stock_elephant -k
40x20
-l 1 -o stock_elephant.sql
$ psql -d gisdb -f stock_elephant.sql
$ gdal_translate -of PNG PG:"host=localhost dbname=gisdb user=gis
password=gis
$ gdal2wktraster.py -r wonderpostgis_banner.png -t
gis_schema.wonderpostgis_banner -k 40x20
-l 1 -o wonderpostigs_banner.sql
$ psql -d gisdb -f wonderpostigs_banner.sql
password=gis
schema=gis_schema table=wonderpostigs_banner"
$ gdal2wktraster.py -r utm.tif -t gis_schema.utm -k 40x20 -s 26711 -l 1 -o
utm.sql
$ psql -d gisdb -f utm.sql
password=gis
Ticket URL: <http://trac.osgeo.org/postgis/ticket/498#comment:7>
