[postgis-devel] [PostGIS] #494: [wktraster] ST_DumpAsPolygons crashes under MingW compiled wktraster (gdal)
trac at osgeo.org
Wed Apr 28 06:13:35 PDT 2010
Reporter: robe | Owner: pracine
Type: defect | Status: new
Priority: medium | Milestone: WKTRaster 0.1.6
Component: wktraster | Version: trunk
Resolution: | Keywords:
Comment (by pracine):
Right. Fixed now in r5580.
Replying to [comment:11 robe]:
> One small problem. The .sql script no longer works because its
complaining geomval and the ST_DumpAsPolygons (ST_DumpAsPolygons is
returning too many fields).
> It seems we are now returning srid as a column in ST_DumpAsPolygons, but
geomval only has a geometry and pixel value.
> Why is it necessary to return srid as a column in ST_DumpAsPolgons.
This does not make sense to me. It makes sense for the DumpAsWKT, but for
ST_DumpAsPolygons, the srid should be encoded in the geometry. So seems
to me it should be rewritten as
> SELECT ST_GeomFromText(wktgeomval.wktGeom, wktgeomval.srid),
wktgeomval.val,
> FROM DumpAsWKTPolygons($1, 1) AS wktgeomval;
> Instead of what it is now which is
> SELECT ST_GeomFromText(wktgeomval.wktGeom), wktgeomval.val,
> wktgeomval.srid FROM DumpAsWKTPolygons($1, 1) AS wktgeomval;
Ticket URL: <http://trac.osgeo.org/postgis/ticket/494#comment:13>
