[postgis-devel] [PostGIS] #513: Can't upload dbf only with gui (without unchecking index?)
trac at osgeo.org
Thu Apr 29 08:39:43 PDT 2010
Reporter: robe | Owner: pramsey
Type: enhancement | Status: new
Priority: medium | Milestone: PostGIS 1.5.2
Component: postgis | Version: 1.5.X
Keywords: |
I have a table that just has attribute data (no geom). Everything goes
fine and well until it tries to create an index.
Failed SQL begins: "CREATE INDEX "parcel_10_data_the_geom_gist" ON
"scratch"."parcel_10_data" using gist ("the_geom" gist_geometry_ops);
COMMIT;
I haven't tried reloading yet, but I suspect it will work if I uncheck the
"CREATE INDEX" checkbox.
I suppose it may be too much to ask, but can we have the gui not try to
create an index if there is no geometry to index even if the user is not
smart enough to uncheck the "CREATE INDEX" option.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/513>
