[postgis-devel] [PostGIS] #494: [wktraster] ST_DumpAsPolygons crashes under MingW compiled wktraster (gdal)
trac at osgeo.org
Thu Apr 29 10:35:14 PDT 2010
Reporter: robe | Owner: pracine
Type: defect | Status: new
Priority: medium | Milestone: WKTRaster 0.1.6
Component: wktraster | Version: trunk
Resolution: | Keywords:
Comment (by jorgearevalo):
I think I've fixed in r5582. I run this query:
select st_astext((st_dumpaspolygons(rast, 1)).geom) as geom,
(st_dumpaspolygons(rast, 1)).val from dummy_rast where rid = 2;
And I get this result (CSV format here)
"geom";"val"
"POLYGON((3427927.75 5793244,3427927.75 5793243.9,3427927.8
5793243.9,3427927.8 5793244,3427927.75 5793244))";253
"POLYGON((3427927.8 5793244,3427927.8 5793243.85,3427927.85
5793243.85,3427927.85 5793243.75,3427928 5793243.75,3427928
5793243.8,3427927.95 5793243.8,3427927.95 5793243.85,3427927.9
5793243.85,3427927.9 5793243.95,3427927.85 5793243.95,3427927.85
5793244,3427927.8 5793244))";254
"POLYGON((3427927.85 5793244,3427927.85 5793243.95,3427927.9
5793243.95,3427927.9 5793244,3427927.85 5793244))";253
"POLYGON((3427927.9 5793244,3427927.9 5793243.95,3427928
5793243.95,3427928 5793244,3427927.9 5793244))";254
"POLYGON((3427927.9 5793243.95,3427927.9 5793243.9,3427927.95
5793243.9,3427927.95 5793243.95,3427927.9 5793243.95))";253
"POLYGON((3427927.95 5793243.95,3427927.95 5793243.85,3427928
5793243.85,3427928 5793243.95,3427927.95 5793243.95))";249
"POLYGON((3427927.75 5793243.9,3427927.75 5793243.85,3427927.8
5793243.85,3427927.8 5793243.9,3427927.75 5793243.9))";250
"POLYGON((3427927.9 5793243.9,3427927.9 5793243.85,3427927.95
5793243.85,3427927.95 5793243.9,3427927.9 5793243.9))";252
"POLYGON((3427927.75 5793243.85,3427927.75 5793243.8,3427927.8
5793243.8,3427927.8 5793243.85,3427927.75 5793243.85))";251
"POLYGON((3427927.8 5793243.85,3427927.8 5793243.8,3427927.85
5793243.8,3427927.85 5793243.85,3427927.8 5793243.85))";253
"POLYGON((3427927.95 5793243.85,3427927.95 5793243.8,3427928
5793243.8,3427928 5793243.85,3427927.95 5793243.85))";253
"POLYGON((3427927.75 5793243.8,3427927.75 5793243.75,3427927.8
5793243.75,3427927.8 5793243.8,3427927.75 5793243.8))";252
"POLYGON((3427927.8 5793243.8,3427927.8 5793243.75,3427927.85
5793243.75,3427927.85 5793243.8,3427927.8 5793243.8))";250
I'll test this polygons with Quantum GIS or OpenJump, to see how do they
look like. So, I leave the ticket open, by now. Related ticket #297.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/494#comment:19>
