[postgis-devel] [PostGIS] #514: [wktraster] Some functions are missing in the XML reference
trac at osgeo.org
Fri Apr 30 08:23:52 PDT 2010
Reporter: pracine | Owner: robe
Type: defect | Status: new
Priority: medium | Milestone: WKTRaster 0.1.6
Component: wktraster | Version: trunk
Resolution: | Keywords:
Old description:
> These functions should added to the XML documentation:
> -st_bandhasnodatavalue
> -st_bandpath
> -postgis_raster_lib_version
> -postgis_raster_lib_build_date
> It would also be good to separate functions accessing (or setting) RASTER
> metadata from functions accessing (or setting) BAND metadata from
> function accessing or setting PIXEL values.
New description:
-st_bandpath
metadata from functions accessing (or setting) BAND metadata from function
accessing or setting PIXEL values. Somehow the same way they are organized
in rtpostgis.sql
Ticket URL: <http://trac.osgeo.org/postgis/ticket/514#comment:2>
