[postgis-devel] [PostGIS] #555: Ability to define a geometry column as Polyhedral surface
PostGIS trac at osgeo.org
Thu Aug 5 15:09:25 PDT 2010
 Reporter:  robe     |       Owner:  colivier
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 2.0.0
Component:  postgis  |     Version:  trunk
 Keywords:           |
Comment(by robe):
 Its already added.  That's how I came across this problem.
 ST_Area I see also returns an answer.  Is that intentional or accidental.
 I'm not sure how to check if the answer is right.
 What I was going to do next is to revise the subset.xsl so can isolate
 testing specific geometries like Polyhedral, so not so much noise in
 testing
Ticket URL: <http://trac.osgeo.org/postgis/ticket/555#comment:3>
