[postgis-devel] [PostGIS] #556: Return value of snprintf not correctly checked
PostGIS trac at osgeo.org
Fri Aug 6 00:58:05 PDT 2010
 Reporter:  hopfgartner  |       Owner:  pramsey
     Type:  defect       |      Status:  new
 Priority:  low          |   Milestone:
Component:  postgis      |     Version:  trunk
 Keywords:               |
 In loader/shp2pgsql-core.c the return value of snprintf is compared to -1.
 Anyway, in case of errors the return value might >= the buffer size if the
 output string was truncated or -1 for other errors see man snprintf.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/556>
