[postgis-devel] [PostGIS] #308: Convert functions using *uchar serializations to use LWGEOM
trac at osgeo.org
Fri Aug 6 02:00:32 PDT 2010
Reporter: pramsey | Owner: pramsey
Type: task | Status: new
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Keywords: |
Comment(by mcayland):
+1 with this approach - you've absolutely got it, deserialize as early as
possible, serialize as late as possible. I'd be quite happy for all of the
geometry functions that take SERIALIZED_FORM to disappear. In fact, when
you think about you'll see that serialized form and deserialized form are
simply input/output functions in exactly the same way as the GML/KML
functions ;)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/308#comment:2>
