[postgis-devel] [PostGIS] #564: ST_DumpPoints support for Polyhedral Surfaces
trac at osgeo.org
Wed Aug 11 01:10:52 PDT 2010
Reporter: robe | Owner: pramsey
Type: task | Status: new
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Keywords: |
Comment(by yabo):
The problem is that ST_DumpPoints doesn't use the ST_IsCollection
function. Here's a patch that fixes the problem and adds some regression
tests to ST_IsCollection and ST_DumpPoints for PolyhedralSurface.
Index: postgis/postgis.sql.in.c
--- postgis/postgis.sql.in.c (revision 5806)
+++ postgis/postgis.sql.in.c (working copy)
@@ -1943,17 +1943,14 @@
i integer;
j integer;
g geometry;
- typ text;
BEGIN
RAISE DEBUG '%,%', cur_path, ST_GeometryType(the_geom);
- -- Special case (MULTI* OR GEOMETRYCOLLECTION) : iterate and return the
DumpPoints of the geometries
- SELECT ST_GeometryType(the_geom) INTO typ;
+ -- Special case collections : iterate and return the DumpPoints of the
geometries
- -- Dont we have an ST_isMulti ?
- IF (typ like 'ST_Multi%' OR typ = 'ST_GeometryCollection') THEN
+ IF (ST_IsCollection(the_geom)) THEN
i = 1;
FOR tmp2 IN SELECT (ST_Dump(the_geom)).* LOOP
Index: regress/iscollection_expected
--- regress/iscollection_expected (revision 5806)
+++ regress/iscollection_expected (working copy)
@@ -13,3 +13,6 @@
empty collection|t
collection|t
collection+|t
+empty polyhedralsurface|t
+polyhedralsurface|t
+polyhedralsurface+|t
Index: regress/dumppoints.sql
--- regress/dumppoints.sql (revision 5806)
+++ regress/dumppoints.sql (working copy)
@@ -93,6 +93,28 @@
SELECT (ST_DumpPoints(g.geom)).*
FROM
(SELECT
+ 'POLYHEDRALSURFACE (((
+ 0 0 0,
+ 0 0 1,
+ 0 1 1,
+ 0 1 0,
+ 0 0 0
+ 0 0 0,
+ 0 1 0,
+ 1 1 0,
+ 1 0 0,
+ 0 0 0
+ )'::geometry AS geom
+ ) AS g
+ ) j;
+SELECT path, ST_AsText(geom)
+FROM (
+ SELECT (ST_DumpPoints(g.geom)).*
+ FROM
+ (SELECT
'GEOMETRYCOLLECTION(
POINT(99 98),
LINESTRING(1 1, 3 3),
Index: regress/dumppoints_expected
--- regress/dumppoints_expected (revision 5806)
+++ regress/dumppoints_expected (working copy)
@@ -35,6 +35,16 @@
{2,2,2}|POINT(6 8)
{2,2,3}|POINT(8 8)
{2,2,4}|POINT(7 6)
+{1,1,1}|POINT(0 0 0)
+{1,1,2}|POINT(0 0 1)
+{1,1,3}|POINT(0 1 1)
+{1,1,4}|POINT(0 1 0)
+{1,1,5}|POINT(0 0 0)
+{2,1,1}|POINT(0 0 0)
+{2,1,2}|POINT(0 1 0)
+{2,1,3}|POINT(1 1 0)
+{2,1,4}|POINT(1 0 0)
+{2,1,5}|POINT(0 0 0)
{1,1}|POINT(99 98)
{2,1}|POINT(1 1)
{2,2}|POINT(3 3)
Index: regress/iscollection.sql
--- regress/iscollection.sql (revision 5806)
+++ regress/iscollection.sql (working copy)
@@ -25,4 +25,6 @@
SELECT 'collection', ST_IsCollection('GEOMETRYCOLLECTION(POINT(0 0))');
SELECT 'collection+', ST_IsCollection('GEOMETRYCOLLECTION(POINT(0 0),
POINT(42 42))');
+SELECT 'empty polyhedralsurface', ST_IsCollection('POLYHEDRALSURFACE
EMPTY');
+SELECT 'polyhedral', ST_IsCollection('POLYHEDRALSURFACE(((0 0 0, 0 0 1, 0
1 1, 0 1 0, 0 0 0)))');
+SELECT 'polyhedral+', ST_IsCollection('POLYHEDRALSURFACE(((0 0 0, 0 0 1,
0 1 1, 0 1 0, 0 0 0)), ((0 0 0, 0 1 0, 1 1 0, 1 0 0, 0 0 0)))');
Ticket URL: <http://trac.osgeo.org/postgis/ticket/564#comment:2>
