[postgis-devel] [PostGIS] #273: ST_GeomFromGML crashes in Windows compiled in MingW
trac at osgeo.org
Thu Aug 12 15:28:23 PDT 2010
Reporter: robe | Owner: colivier
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Keywords: |
Comment(by robe):
I think this problem is resolved, but I'm trying to retrace my steps to
figure out the culprit. On my test box I can build PostGIS 2.0.0 and
PostGIS 1.5.2 with dynamically linking to libxml 2.7.6. When I do that
the resulting postgis-.dll is much smaller and clearly has a
libxml-2-2.dll dependency, but doesn't crash with the above examples.
On the box we usually use to build on, dynamically linking still results
in a crashing postgis-..dll with the above examples. I thought maybe it
was the libxml-2-2.dll, but swapping out with the one built on our
production still works.
I'm suspecting its upgrading the auto conf or lib tool that did the trick
but haven't verified yet. On my test box I'm running a newer version (of
at least libtool)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/273#comment:48>
