[postgis-devel] [PostGIS] #573: ST_Contains(geog, geog) gives wrong answer
trac at osgeo.org
Fri Aug 20 09:32:27 PDT 2010
Reporter: pramsey | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 1.5.2
Component: postgis | Version: 1.5.X
Keywords: |
Comment(by pramsey):
The improvement has removed the total failure from the second case. The
answers may still be "wrong" depending on how you interpret the
containment region of the polygon.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/573#comment:3>
