[postgis-devel] [PostGIS] #576: 3d distance functions
trac at osgeo.org
Sat Aug 21 06:05:04 PDT 2010
Reporter: nicklas | Owner: pramsey
Type: enhancement | Status: new
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Keywords: |
We don't have distance functions that can handle third dimmension yet.
I have copied a spike where I have put the first steps.
http://svn.osgeo.org/postgis/spike/nicklas/dist3d/
So far it is only working in the simple cases
point-point[[BR]]
point-linestring[[BR]]
The rest is a little bit more tricky.
But it is a start and the line-point and point-point cases should work
with all the distance-functions.
I have put a suffix on the 3D-versions of the functions as showed below.
Is that a good way of naming them?[[BR]]
We have to have special 3D-functions so it is possible to do the 2D-
calculation even if the z-value is present.
The new functions are named:
ST_Distance3d[[BR]]
ST_MaxDistance3d[[BR]]
ST_ClosestPoint3d[[BR]]
ST_Shortestline3d[[BR]]
ST_Longestline3d[[BR]]
ST_Dwithin3d[[BR]]
ST_DFullywithin3d[[BR]]
There is no indexes involved and no use of the faster way of calculating
distances.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/576>
