[postgis-devel] [PostGIS] #577: possible memory leak with buffer()
trac at osgeo.org
Sat Aug 21 11:33:10 PDT 2010
Reporter: davideps | Owner: robe
Type: defect | Status: closed
Priority: medium | Milestone:
Component: postgis | Version: 1.3.X
Resolution: invalid | Keywords: memory buffer intersect dwithin
Comment(by davideps):
Nicklas,
Thank you for your comments. EXPLAIN shows p1 is a seq scan & p2 uses gist
index. I will try to upgrade when I have time.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/577#comment:6>
