[postgis-devel] [wktraster] Core tests failure for r5841
Pierre Racine
Pierre.Racine at sbf.ulaval.ca
Mon Aug 23 07:53:49 PDT 2010
fixed in r5864
Sorry for that. Probably forgot to make check.
Pierre
>-----Original Message-----
>From: postgis-devel-bounces at postgis.refractions.net [mailto:postgis-devel-
>bounces at postgis.refractions.net] On Behalf Of Pierre Racine
>Sent: 23 août 2010 09:24
>To: PostGIS Development Discussion
>Subject: Re: [postgis-devel] [wktraster] Core tests failure for r5841
>Probably my fault. Double check...
>Pierre
>>bounces at postgis.refractions.net] On Behalf Of Jorge Arévalo
>>Sent: 23 août 2010 07:39
>>On Mon, Aug 23, 2010 at 1:04 PM, Mateusz Loskot <mateusz at loskot.net> wrote:
>>> Hi,
>>> I've noticed current revision of WKT Raster is broken.
>>> Running the core tests for r5841 ends up with assertion and
>>> load of warnings:
>>> ./testapi
>>> 1111 pixtype = 2
>>> Raster starts with 0 bands
>>> First point on convexhull ring is 0.5,0.5
>>> Second point on convexhull ring is 256.5,1280.5
>>> Third point on convexhull ring is 1280.5,1536.5
>>> Fourth point on convexhull ring is 1024.5,256.5
>>> Fifth point on convexhull ring is 0.5,0.5
>>> Testing polygonize function
>>> Testing 1BB band
>>> WARNING: rt_band_set_nodata: NODATA value for 1BB band got truncated from 2
>>> to 0
>>> WARNING: rt_band_set_nodata: NODATA value for 1BB band got truncated from 3
>>> to 1
>>> WARNING: Pixel value for 1BB band got truncated from 2 to 0
>>> WARNING: Pixel value for 1BB band got truncated from 3 to 1
>>> Testing 2BB band
>>> WARNING: rt_band_set_nodata: NODATA value for 2BUI band got truncated from 4
>>> to 0
>>> WARNING: rt_band_set_nodata: NODATA value for 2BUI band got truncated from 5
>>> to 1
>>> WARNING: Pixel value for 2BUI band got truncated from 4 to 0
>>> WARNING: Pixel value for 2BUI band got truncated from 5 to 1
>>> Testing 4BUI band
>>> WARNING: rt_band_set_nodata: NODATA value for 4BUI band got truncated from
>>> 16 to 0
>>> 17 to 1
>>> WARNING: Pixel value for 4BUI band got truncated from 35 to 3
>>> Testing 8BUI band
>>> WARNING: rt_band_set_nodata: NODATA value for 8BUI band got truncated from
>>> 256 to 0
>>> WARNING: Pixel value for 8BUI band got truncated from 256 to 0
>>> Testing 8BSI band
>>> WARNING: rt_band_set_nodata: NODATA value for 8BSI band got truncated from
>>> -129 to 127
>>> 129 to -127
>>> WARNING: Pixel value for 8BSI band got truncated from -129 to 127
>>> WARNING: Pixel value for 8BSI band got truncated from 129 to -127
>>> Testing 16BSI band
>>> WARNING: rt_band_set_nodata: NODATA value for 16BSI band got truncated from
>>> -32769 to 32767
>>> 32769 to -32767
>>> WARNING: Pixel value for 16BSI band got truncated from -32769 to 32767
>>> WARNING: Pixel value for 16BSI band got truncated from 32769 to -32767
>>> ERROR: Coordinates ouf of range
>>> Testing 16BUI band
>>> WARNING: rt_band_set_nodata: NODATA value for 16BUI band got truncated from
>>> 65536 to 0
>>> WARNING: Pixel value for 16BUI band got truncated from 65536 to 0
>>> Testing 32BUI band
>>> WARNING: rt_band_set_nodata: NODATA value for 32BUI band got truncated from
>>> 4.29497e+09 to 0
>>> WARNING: Pixel value for 32BUI band got truncated from 4.29497e+09 to 0
>>> Testing 32BSI band
>>> WARNING: rt_band_set_nodata: NODATA value for 32BSI band got truncated from
>>> 2.14748e+09 to -2.14748e+09
>>> WARNING: Pixel value for 32BSI band got truncated from 2.14748e+09 to
>>> -2.14748e+09
>>> Testing 32BF band
>>> Testing 64BF band
>>> Testing band hasnodata flag
>>> testapi: rt_api.c:545: rt_band_get_data: Assertion `((void *)0) != band'
>>> failed.
>>> make[2]: *** [check] Aborted
>>> make[2]: Leaving directory
>>> `/home/mloskot/dev/wktraster/_svn/trunk/test/core'
>>> make[1]: *** [check] Error 2
>>> make[1]: Leaving directory `/home/mloskot/dev/wktraster/_svn/trunk/test'
>>> make: *** [check] Error 2
>>> The assertion is serious and happens in crucial function.
>>> I checked and the last healthy revision seems to be r5811.
>>> Pierre, Jorge, could you re-validate your recent commits?
>>> You do run "make check" before every commit, don't you?
>>> Best regards,
>>> Mateusz Loskot, http://mateusz.loskot.net
>>> postgis-devel mailing list
>>> postgis-devel at postgis.refractions.net
>>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
>>The problem seems to be in the 1BB band of the testing raster. Working
>>on it... And yes, I always do make check before commit, but I'll check
>>my commits again :-)
>>Best regards,
>>Jorge Arévalo
>>DEIMOS Space
>>Internet & Mobilty Division
>>Ronda de Poniente 19. Edificio Fiteni VI, portal 2, 2º
>>28760 Tres Cantos (Madrid)
>>Tel: +34 91 806 34 50 - ext: 155
>>jorge.arevalo at deimos-space.com
>>http://gis4free.wordpress.com
