[postgis-devel] [wktraster] Core tests failure for r5841
Pierre Racine
Pierre.Racine at sbf.ulaval.ca
Tue Aug 24 05:48:47 PDT 2010
Mateusz,
Could you get your regression test to work?
I reverted the drop option to "yes".
Pierre
>-----Original Message-----
>From: postgis-devel-bounces at postgis.refractions.net [mailto:postgis-devel-
>bounces at postgis.refractions.net] On Behalf Of Mateusz Loskot
>Sent: 24 août 2010 06:48
>To: Jorge Arévalo
>Cc: PostGIS Development Discussion
>Subject: Re: [postgis-devel] [wktraster] Core tests failure for r5841
>On 24/08/10 11:32, Jorge Arévalo wrote:
>> 2010/8/24 Mateusz Loskot<mateusz at loskot.net>:
>>> On 24/08/10 11:08, Jorge Arévalo wrote:
>>>> A minor issue: the rtpostgis_reg database created for postinstall
>>>> check is not deleted by default. Mateusz, did you change it for any
>>>> reason? (r5822 was the previous version)
>>> Which changeset you mean exactly. The following is r5823
>>> and some changes in test/regress/run_test.in happened.
>> Yes, sorry, my mistake. I mean the last change on
>> test/regress/run_test.in. A little change:
>> http://trac.osgeo.org/postgis/changeset/5823/spike/wktraster/test/regress/run_test.in
>> May I change the DROP option again, or is a bad idea?
>IMO, we should follow PostGIS' approach:
>AFAIU, it is yes, I'd re-enable the drop option.
>Best regards,
>Mateusz Loskot, http://mateusz.loskot.net
>_______________________________________________
>postgis-devel mailing list
>postgis-devel at postgis.refractions.net
>http://postgis.refractions.net/mailman/listinfo/postgis-devel
