[postgis-devel] Oracle SDO_GEOMETRY vs PostGIS WKT
Andrea Peri
aperi2007 at gmail.com
Wed Aug 25 04:53:02 PDT 2010
>Yes, Oracle Spatial's data model seems to be a topological model [1].
>Thanks for pointing me to that fact. As I said, I find it some
>tangled, and I'm looking for the reason. Or am I talking non-sense?
>Best regards,
>Jorge
the topological model of Oracle is a model with Face-Edges-Nodes.
But it don't use the "SDO_Geometry",
but instead it use the other type "SDO_TOPO_Geometry".
so if you load using a SDO_Geometry the lines between two polygons are
duplicated.
If you don't want the duplication you must use SDO_TopoGeometry instead of
SDO_Geometry.
I don't know if a "SDO_Topo_Geometry" is readable as a kind of
"SDO_Geometry".
Regards,
Andrea Peri
qwerty àèìòù
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20100825/18d60437/attachment.html>
