[postgis-devel] [PostGIS] #576: 3d distance functions
PostGIS trac at osgeo.org
Tue Aug 31 14:02:23 PDT 2010
 Reporter:  nicklas      |       Owner:  nicklas
     Type:  enhancement  |      Status:  assigned
 Priority:  medium       |   Milestone:  PostGIS 2.0.0
Component:  postgis      |     Version:  trunk
 Keywords:               |
Comment(by bitner):
 Regina,
 I prefer explicit 3D naming for functions that use the third dimension.
 The underlying assumption right now is that all functions are 2D.  A lot
 of people just throw data into their dbs without even knowing that it has
 a third dimension and they would be thrown quite off guard if all of the
 sudden they started getting different results. If there is a SQL/MM
 standard for naming, all the better.
 David
Ticket URL: <http://trac.osgeo.org/postgis/ticket/576#comment:14>
