[postgis-devel] [PostGIS] #670: ST_SharedPaths
PostGIS trac at osgeo.org
Thu Dec 2 22:11:44 PST 2010
 Reporter:  strk         |       Owner:  strk
     Type:  enhancement  |      Status:  new
 Priority:  medium       |   Milestone:  PostGIS 2.0.0
Component:  postgis      |     Version:  trunk
 Keywords:               |
Comment(by robe):
 Sandro,
 I put in some documentation for ST_SharedPaths and then passed it thru the
 grinder and managed to crash it.  It broke on this query on my Windows 7
 PostgreSQL 9.0 32 bit.  Can you check and see if the below works on yours.
 SELECT ST_SharedPaths(foo1.the_geom, foo2.the_geom) As result,
 ST_AsText(foo1.the_geom) As ref1_geom, ST_AsText(foo2.the_geom) As
 ref2_geom FROM ((SELECT ST_SetSRID(ST_Point(i,j),4326) As the_geom FROM
 (SELECT a*1.11111111 FROM generate_series(-10,50,10) As a) As i(i) CROSS
 JOIN generate_series(40,70, 15) j ORDER BY i,j )) As foo1 CROSS JOIN
 ((SELECT ST_Buffer(ST_SetSRID(ST_Point(i,j),4326), j*0.05) As the_geom
 FROM (SELECT a*1.11111111 FROM generate_series(-10,50,10) As a) As i(i)
 CROSS JOIN generate_series(40,70, 20) As j ORDER BY i, i*j, j)) As foo2
 LIMIT 2;
Ticket URL: <http://trac.osgeo.org/postgis/ticket/670#comment:3>
