[postgis-devel] [PostGIS] #670: ST_SharedPaths
trac at osgeo.org
Fri Dec 3 01:06:22 PST 2010
Reporter: strk | Owner: strk
Type: defect | Status: new
Priority: high | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Keywords: |
Comment(by strk):
Note the table was created with this query:
strk=# create table bug670 as SELECT foo1.the_geom as g1, foo2.the_geom As
g2
FROM ((SELECT ST_SetSRID(ST_Point(i,j),4326) As the_geom FROM
(SELECT a*1.11111111 FROM generate_series(-10,50,10) As a) As i(i) CROSS
JOIN generate_series(40,70, 15) j ORDER BY i,j )) As foo1 CROSS JOIN
((SELECT ST_Buffer(ST_SetSRID(ST_Point(i,j),4326), j*0.05) As the_geom
FROM (SELECT a*1.11111111 FROM generate_series(-10,50,10) As a) As i(i)
CROSS JOIN generate_series(40,70, 20) As j ORDER BY i, i*j, j)) As foo2
LIMIT 2;
Ticket URL: <http://trac.osgeo.org/postgis/ticket/670#comment:6>
