[postgis-devel] [PostGIS] #676: ST_Snap
PostGIS trac at osgeo.org
Fri Dec 3 09:37:43 PST 2010
#676: ST_Snap
 Reporter:  strk         |       Owner:  strk
     Type:  enhancement  |      Status:  new
 Priority:  medium       |   Milestone:  PostGIS 2.0.0
Component:  postgis      |     Version:  trunk
 Keywords:               |
Comment(by robe):
 It should be pretty much the same in MingW as you do on Linux.  I didn't
 do anything different for ST_SharedPaths for example.
 I thought maybe it was my autoconf settings caching because that has
 happened before, but blowing out and redownloading trunk and also
 recompiling trunk geos didn't fix the issue as it usually does in those
 cases.
 Maybe someone else who is running the latest GEOS trunk can test as well
 to confirm it's not just a MingW issue.
 Kevin -- if you are around -- is Hudson testing against GEOS 3.2 or 3.3 --
 though I'm not sure Hudson flags install errors since all goes smoothly
 except for the install.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/676#comment:3>
