[postgis-devel] [PostGIS] #678: Can't compile shp2pgsql or pgsql2shp under MingW
PostGIS trac at osgeo.org
Fri Dec 3 15:19:02 PST 2010
 Reporter:  robe     |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 2.0.0
Component:  postgis  |     Version:  trunk
 Keywords:           |
Comment(by robe):
 Sorry for the lame questions I see a libitll config option I don't recall
 seeing befor either.  That could be because I wasn't looking.  Should this
 be pointing at some config file or the dll executable.  I assume its not
 to a config fiel since it doesn't have config as part of the variable name
Ticket URL: <http://trac.osgeo.org/postgis/ticket/678#comment:2>
