[postgis-devel] How does copyright work and how to credit.
Paul Ramsey
pramsey at opengeo.org
Sat Dec 4 19:55:31 PST 2010
Nik,
They can't copyright their idea, but they can patent it. Probably the
algorithm you are following is not patented, but if that kind of thing
worries you, you could do a patent search. I'd include the URL
reference as you suggest, and continue the work under your own
copyright.
P.
On Sat, Dec 4, 2010 at 12:00 PM, Nicklas Avén
<nicklas.aven at jordogskog.no> wrote:
> Hallo
> The code for line to line distance-calculations that is not yet
> comitted is mostly taken from here:
> http://softsurfer.com/Archive/algorithm_0106/algorithm_0106.htm
> As you can see in the attachment I have not done any big rewriting.
> It says on the page with the algorithms that it can be used, but then
> they want their copyright to be included.
> I don't know how things like this works. I mean I have definitely used
> their idea. Is it their idea that is copyrighted or is it their exactly
> way of writing it. I mean, I hope it isn't the idea.
> And it feels quite silly to rewrite it more than necessarily just to
> make it look different.
> What I would like to do is to just write a note in a comment that the
> algorithm comes from softsurfer.com and can be found at page :
> Would that be ok?
> Thanks
> Nicklas
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
