[postgis-devel] [PostGIS] #680: Surprise surprise: Crash on geography ST_AsBinary for PointM
trac at osgeo.org
Tue Dec 7 22:24:38 PST 2010
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Keywords: |
Well this is as far as I got before my server crashed with your new
changes.
-- this is okay --
SELECT geography(foo1.the_geom) As result
FROM ((SELECT ST_SetSRID(ST_MakePointM(i,j,m),4326) As the_geom FROM
generate_series(-10,50,10) As i CROSS JOIN generate_series(50,70, 20) AS j
CROSS JOIN generate_series(1,2) As m ORDER BY i, j, i*j*m)) As foo1 LIMIT
3;
-- but then applying an ST_AsBinary -- get a crash, though
SELECT ST_AsBinary(geography(foo1.the_geom)) As result
3;
-- ST_AsText doesn't crash but fails PostGIS 1.5 regression --
On 1.5
SELECT ST_AsText(geography(foo1.the_geom)) As result
3;
-- returns
POINTM(-10 50 2)
POINTM(-10 50 1)
POINTM(-10 70 2)
On new 2.0 the M is missing
POINT(-10 50)
POINT(-10 50)
POINT(-10 70)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/680>
