[postgis-devel] [PostGIS] #691: test_wkt_in_multipoint cunit test	failng
    trac at osgeo.org
    Thu Dec  9 05:55:00 PST 2010
 Reporter:  robe     |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 2.0.0
Component:  postgis  |     Version:  trunk
 Keywords:           |
 I'm not sure how long this has been failing -- I think since your big load
 of changes.
 Should all cunit tests be passing?
 Getting failure on
 Test: test_wkt_in_multipoint ... FAILED
     1. cu_in_wkt.c:145  - CU_ASSERT_STRING_EQUAL(r,s)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/691>
