[postgis-devel] [PostGIS] #691: test_wkt_in_multipoint cunit	test failng
    trac at osgeo.org
    Fri Dec 10 09:09:04 PST 2010
 Reporter:  robe     |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 2.0.0
Component:  postgis  |     Version:  trunk
 Keywords:           |
Comment(by robe):
 Yes 1.5 branch and 1.5.2 stable all cunit tests pass (note: all the
 postgresql .sql tests pass in PostGIS 2.0 and in 1.5.2), can't test on 1.5
 branch at the moment because I always download the sql regress tests from
 the tar ball (or have to do a dos2unix) since svn the regress tests the
 line breaks are always screwed up on half of the tests so half of them
 don't pass though (hmm some do) and interestingly from overwriting from
 tar ball they always pass.
 How do these things get half-way screwed up in svn but come out fine in
 tar?
 Output from 1.5 branch cunit
 --Run Summary: Type      Total     Ran  Passed  Failed
                suites        4       4     n/a       0
                tests        43      43      43       0
                asserts     633     633     633       0
Ticket URL: <http://trac.osgeo.org/postgis/ticket/691#comment:8>
