[postgis-devel] [PostGIS] #691: test_wkt_in_multipoint cunit test failng
trac at osgeo.org
Fri Dec 10 10:02:01 PST 2010
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Keywords: |
Comment(by robe):
Well 1.5.2 works okay (all the .sql including regress pass) - did you add
that before or after 1.5.2 release?. 1.5.3 regress is failing but it could
be because of the line break issue because whole thing is filled with ^M
so will have to get back to you on that.
2.0 having trouble at the moment getting the sql tests to run its just
coughing up screen junk. I thought last time I was successfull all
passed, but I could have been mistaken and missed a line.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/691#comment:10>
