[postgis-devel] [PostGIS] #697: cunit failures on Polyhedral surface
trac at osgeo.org
Fri Dec 10 10:21:51 PST 2010
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Keywords: |
Test: polyhedralsurface_parse ... FAILED
1. cu_surface.c:335 - CU_ASSERT_STRING_EQUAL("geometry contains non-
closed rings",cu_error_msg)
2. cu_surface.c:341 - CU_ASSERT_STRING_EQUAL("geometry contains non-
Ticket URL: <http://trac.osgeo.org/postgis/ticket/697>
