[postgis-devel] [PostGIS] #704: eol-style setting on regression expected files is wrong
trac at osgeo.org
Mon Dec 13 05:34:42 PST 2010
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 1.5.3
Component: postgis | Version: 1.5.X
Keywords: |
Okay I think I have narrowed my issues with testing the sql regress files
to whenever any of you makes changes to these files, the file from then on
fails for me.
It seems that some of these have svn tag and some do not
svn:eol-style=native
That doesn't work. E.g. regress_expected has that and anytime anyone
changes it, I have to resave the file.
Shouldn't all the _expected files be marked
svn:eol-style=LF
PostgreSQL as far as I can tell (unless I change the default configuration
-- even the windows version will always output with LF and not CRLF unless
I explicitly change in the config).
Ticket URL: <http://trac.osgeo.org/postgis/ticket/704>
