[postgis-devel] [PostGIS] #705: ST_Distance on points crashes server
trac at osgeo.org
Mon Dec 13 07:05:25 PST 2010
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Keywords: |
I assume this is a result of recent changes since it wasn't crashing last
I tried on Friday.
-- this crashes --
SELECT ST_Distance(foo1.the_geom, foo2.the_geom)
FROM (SELECT ST_GeomFromText('POINT(-11.1111111 40)') UNION ALL
SELECT ST_GeomFromText('POINT(-11.1111111 55)') ) As
foo1(the_geom)
CROSS JOIN (SELECT ST_GeomFromText('POINT(-11.1111111 40)')
UNION ALL SELECT ST_GeomFromText('POINT(-11.1111111 55)') ) As
foo2(the_geom);
-- this doesn't crash -
foo1(the_geom)
foo2(the_geom) limit 1;
Ticket URL: <http://trac.osgeo.org/postgis/ticket/705>
