[postgis-devel] [PostGIS] #708: ST_ExteriorRing POLYGON EMPTY crash (was: ST_DumpPoints POLYGON EMPTY crash)
PostGIS trac at osgeo.org
Tue Dec 14 04:39:22 PST 2010
 Reporter:  robe     |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 2.0.0
Component:  postgis  |     Version:  trunk
 Keywords:           |
Old description:
> SELECT ST_DumpPoints(ST_GeomFromText('POLYGON EMPTY',4326)) As result;
New description:
 SELECT ST_ExteriorRing(ST_GeomFromText('POLYGON EMPTY',4326)) As result;
 Which I think is the cause of ST_DumpPoints crashing as well
Comment(by robe):
 Maxime,
 I think ST_DumpPoints is breaking by virtue of the fact that
 ST_ExteriorRing is the real culprit and it uses that when it sees a
 polygon type.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/708#comment:4>
