[postgis-devel] [PostGIS] #681: ST_AsGML crashes on POLYGON EMPTY
trac at osgeo.org
Tue Dec 14 05:36:10 PST 2010
Reporter: robe | Owner: colivier
Type: defect | Status: closed
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Resolution: fixed | Keywords:
Changes (by robe):
* status: new => closed
* resolution: => fixed
Comment:
I was wrong your most recent change does fix the ST_AsKML issue. However
a small little problem still exists.
SELECT ST_AsKML(ST_GeomFromText('POLYGON EMPTY'))
Gives the message:
ERROR: Input geometry has unknown (-1) SRID
I thought our new UNKNOWN is 0 no or has this constant not been flipped
yet?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/681#comment:5>
