[postgis-devel] [PostGIS] #709: cunit tests fail cu_tester crashes on out_kml_test_precision KML test
PostGIS trac at osgeo.org
Tue Dec 14 05:54:05 PST 2010
 Reporter:  robe     |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  blocker  |   Milestone:  PostGIS 2.0.0
Component:  postgis  |     Version:  trunk
 Keywords:           |
Comment(by robe):
 These two problems might be related -- the below query crashes the server:
 SELECT ST_AsKML(ST_GeomFromEWKT('SRID=4326;POLYGON((-8.1111111
 60,-8.16875525879031 59.4147290339516,-8.33947250246614
 58.8519497029047,-8.61670226309236 58.3332893009412,-8.98979075644036
 57.8786796564404,-9.44440040094119 57.5055911630924,-9.96306080290473
 57.2283614024661,-10.5258401339516 57.0576441587903,-11.1111111
 57,-11.6963820660484 57.0576441587903,-12.2591613970953
 57.2283614024661,-12.7778217990588 57.5055911630924,-13.2324314435596
 57.8786796564404,-13.6055199369076 58.3332893009412,-13.8827496975339
 58.8519497029047,-14.0534669412097 59.4147290339516,-14.1111111
 60,-14.0534669412097 60.5852709660484,-13.8827496975339
 61.1480502970953,-13.6055199369076 61.6667106990588,-13.2324314435597
 62.1213203435596,-12.7778217990588 62.4944088369076,-12.2591613970953
 62.7716385975339,-11.6963820660484 62.9423558412097,-11.1111111
 63,-10.5258401339516 62.9423558412097,-9.96306080290474
 62.7716385975339,-9.4444004009412 62.4944088369076,-8.98979075644036
 62.1213203435596,-8.61670226309237 61.6667106990588,-8.33947250246614
 61.1480502970953,-8.16875525879031 60.5852709660484,-8.1111111 60))'));
Ticket URL: <http://trac.osgeo.org/postgis/ticket/709#comment:1>
