[postgis-devel] [PostGIS] #681: ST_AsGML and ST_AsKML crashes on POLYGON EMPTY or acts really bizarre
trac at osgeo.org
Wed Dec 15 09:48:15 PST 2010
Reporter: robe | Owner: colivier
Type: defect | Status: reopened
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Resolution: | Keywords:
Comment(by pramsey):
I have made no fixes to AsGML, I fully expect it to do all kinds of nasty
things when fed EMPTY.
For AsKML, I have checked in a fix to the crashing at r6402. Right now I
return NULL on empty. The 1.5 behavior was that the empty got coerced to
geometrycollection empty, which then failed the "no geometry collections
allowed" test and failed with an error. I can change to error out on empty
if that is preferred. There seems to be no representation for empty in
KML, although we could invent one (<polygon></polygon>) I'm not sure what
Google Earth would do with it. Research project?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/681#comment:11>
