[postgis-devel] Into the Soup
Paul Ramsey
pramsey at opengeo.org
Wed Dec 15 14:59:55 PST 2010
Regina,
If I can't break myself of them, maybe no one can and we should leave
them in as a legacy. Regardless, I'm working on indexes now :)
And did you notice, we can use gserialized under geometry!
Paul
On Wed, Dec 15, 2010 at 2:57 PM, Paragon Corporation <lr at pcorp.us> wrote:
> Paul,
> The first thing you'll do is remove the functions AsText and Length so you
> can't use them anymore in examples, right? Remmber ST_Everything was your
> idea.
> Or is there a reason to keep these things around?
> Thanks,
> Regina
> -----Original Message-----
> From: postgis-devel-bounces at postgis.refractions.net
> [mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of Paul
> Ramsey
> Sent: Wednesday, December 15, 2010 5:25 PM
> To: PostGIS Development Discussion
> Subject: [postgis-devel] Into the Soup
> You'll noticed that in the last couple commits, this fun little block of
> code appeared:
> http://trac.osgeo.org/postgis/browser/trunk/postgis/lwgeom_pg.h#L71
> All those previous commits removing SERIALIZED_LWGEOM and various appears to
> memcpy have been attempts to cleanse the code base of direct appeals to the
> underlying serialization, and while not complete, a large swathe of the code
> base is now clean, so much so that I can now define PG_LWGEOM to be
> GSERIALIZED and have things sort of magically work...
> postgis20=# select astext('POINT(0 0)'::geometry);
> astext
> POINT(0 0)
> (1 row)
> postgis20=# select length('LINESTRING(0 0, 1 1)'::geometry);
> length
> 1.4142135623731
> (1 row)
> postgis20=# select st_relate('LINESTRING(0 0, 1 1)', 'POINT(0.5 0.5)');
> st_relate
> 0F1FF0FF2
> (1 row)
> In the examples above, the LWGEOM_in function is converting the text to a
> GSERIALIZED, which is passed to the next function and then output as WKT and
> length checked and GEOS operated on. Magical.
> This trick is pretty cool, but there are still come functions that appeal
> directly to serialization that need to be fix, and most importantly the
> index bindings need to be swapped over to use the bindings in geography. It
> will be interesting to see if that can also be done conditionally.
> Paul
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
