[postgis-devel] [PostGIS] #715: Online regression failures don't stop 'make check'
trac at osgeo.org
Thu Dec 16 09:13:01 PST 2010
Reporter: pramsey | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Keywords: |
When I run 'make check' with the current r6417 build system, the 'make
check' does not stop when the online regression tests have a failure, it
just moves merrily on to do make check in liblwgeom (which is the reverse
of the old order, BTW, which I preferred: first liblwgeom, then online).
Ticket URL: <http://trac.osgeo.org/postgis/ticket/715>
