[postgis-devel] Death to Pointless Operators
    Paul Ramsey
    pramsey at opengeo.org
    Sun Dec 19 11:07:25 PST 2010
When you say ~, do you mean =~ ?
Because ~ never meant equality of any sort, it meant contained.
P.
On Sun, Dec 19, 2010 at 8:59 AM, Paragon Corporation <lr at pcorp.us> wrote:
> =  would mean bounding box equals as it does now except it would take
> advantage of a gist index where it can.  I don't think we can change that.
> Its consistent with all operators are bounding box checks.
> So regardless of if its doing btree / gist it should mean the same thing is
> my point.
> The distinctions look like just implementation artifacts I as a user don't
> really care to know about.
> My concern with keeping ~ going is that its broken in the sense that if you
> are a long time user of PostGIS and actualy used it  you still have in your
> mind that it means geometric equality.
> When you port your apps over from say 1.3 (even 1.4 and 1.5 if you had done
> a soft upgrade) -- the meaning of it has suddenly changed.
> Your apps aren't breaking -- there just returning the wrong answers which is
> much harder to debug than to get back a " I'm sorry  ~ doesn't exist."
> R
> -----Original Message-----
> From: postgis-devel-bounces at postgis.refractions.net
> [mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of Paul
> Ramsey
> Sent: Sunday, December 19, 2010 11:38 AM
> To: PostGIS Development Discussion
> Subject: Re: [postgis-devel] Death to Pointless Operators
> Would '=' be equivalent to ST_Equals, ST_OrderingEquals or
> bounding-box-equals?
> P
> On Sun, Dec 19, 2010 at 7:32 AM, Paragon Corporation <lr at pcorp.us> wrote:
>>>> If you get rid of anything you should really get rid of that ~ --
>>>> its just confusing because it means something completely different
>>>> as Nicklas mentioned a while ago (when you are talking about the
>>>> built-in polygon/point and I think even pgsphere --
>>> ~ is the opposite of @. But it can be any symbol we like. How about !@ ?
>>> Actually that would be a bad symbol pairing (the equals/notequals
>>> parallel
>> is not correct, A = B does not imply B != A). A better one would be if
>> we used >> and << since they are commutative relations.
>>> But that would break backwards compatibility which above you are
>>> telling
>> me is a big deal for the operators that people don't actually use!
>>> So, for sheer conservative curmudgoenliness, I would suggest we leave
>> and @ as they are.
>> Like I said if we can I would prefer to overload the = operator like
>> ltree does so I don't have to go around explaining why we have ~ and =
>> which mean the same thing but one uses an index and one doesn't.
>> Or you think there is a benefit there of keeping them separate?
>> http://www.postgresql.org/docs/current/interactive/ltree.html
>> postgis-devel mailing list
>> postgis-devel at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
