[postgis-devel] [PostGIS] #729: ST_MakeLine aggregate function crashes with empty geometries
PostGIS trac at osgeo.org
Thu Dec 23 10:48:41 PST 2010
 Reporter:  robe     |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 2.0.0
Component:  postgis  |     Version:  trunk
 Keywords:           |
 This is with gserialized defined.
 -- ST_MakeLine aggregate crashes with empty geometries
 SELECT ST_MakeLine(foo1.the_geom) As result
                                                         FROM ((SELECT
 ST_GeomFromText('POINT EMPTY',4326) As the_geom
                         UNION ALL SELECT ST_GeomFromText('MULTIPOINT
                         UNION ALL SELECT ST_GeomFromText('MULTIPOLYGON
                         UNION ALL SELECT ST_GeomFromText('LINESTRING
                         UNION ALL SELECT ST_GeomFromText('MULTILINESTRING
 EMPTY',4326) As the_geom ) ) As foo1
Ticket URL: <http://trac.osgeo.org/postgis/ticket/729>
