[postgis-devel] [PostGIS] #734: Topology fail some check
    trac at osgeo.org
    Mon Dec 27 02:43:07 PST 2010
 Reporter:  aperi2007  |       Owner:  strk
     Type:  defect     |      Status:  new
 Priority:  medium     |   Milestone:  PostGIS 2.0.0
Component:  topology   |     Version:  1.5.X
 Keywords:             |
 try-ing to compile last trunk (r6511) with topology option.
 During make check phase I have this error:
  PostgreSQL 9.0.2 on i686-pc-linux-gnu, compiled by GCC gcc (Debian
 4.3.2-1.1) 4.3.2, 32-bit
  Postgis 2.0.0SVN - 2010-12-27 10:44:08
    GEOS: 3.3.0-CAPI-1.7.0
    PROJ: Rel. 4.7.1, 23 September 2009
 Running tests
  regress/legacy_validate. ok
  regress/legacy_predicate. ok
  regress/legacy_invalid. ok
  regress/sqlmm. failed (diff expected obtained:
 /tmp/pgis_reg_12093/test_4_diff)
  regress/legacy_query. ok
  regress/addnode. ok
  regress/addedge. ok
  regress/addface. ok
  regress/st_getfacegeometry. ok
 Run tests: 9
 Failed: 1
 make[2]: *** [check] Error 1
 make[2]: Leaving directory
 `/home/postgres/software/postgis/postgis-2.0.0SVN/topology/test'
 make[1]: *** [check] Error 2
 make[1]: Leaving directory
 `/home/postgres/software/postgis/postgis-2.0.0SVN/topology'
 make: *** [check] Error 1
 I run it on a debian lenny 32 bit with geos-svn last version and
 postgresql 9.0.2.
 Regards.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/734>
