[postgis-devel] [PostGIS] #735: regress failed
trac at osgeo.org
Tue Dec 28 07:13:13 PST 2010
Reporter: aperi2007 | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Keywords: |
during the check phase of compile the last version of postgis trunk I see
three errors:
regress, lwgeom-regres and ticket.
PostgreSQL 9.0.2 on i686-pc-linux-gnu, compiled by GCC gcc (Debian
4.3.2-1.1) 4.3.2, 32-bit
Postgis 2.0.0SVN - 2010-12-28 15:05:59
GEOS: 3.3.0-CAPI-1.7.0
PROJ: Rel. 4.7.1, 23 September 2009
Running tests
loader/Point.............. ok
loader/PointM.............. ok
loader/PointZ.............. ok
loader/MultiPoint.............. ok
loader/MultiPointM.............. ok
loader/MultiPointZ.............. ok
loader/Arc.............. ok
loader/ArcM.............. ok
loader/ArcZ.......... ok
loader/Polygon.............. ok
loader/PolygonM.............. ok
loader/PolygonZ.............. ok
regress. failed (diff expected obtained:
/tmp/pgis_reg_31671/test_13_diff)
regress_index. ok
regress_index_nulls. ok
lwgeom_regress. failed (diff expected obtained:
/tmp/pgis_reg_31671/test_16_diff)
regress_lrs. ok
removepoint. ok
setpoint. ok
simplify. ok
snaptogrid. ok
affine. ok
measures. ok
long_xact. ok
ctors. ok
sql-mm-serialize. ok
sql-mm-circularstring. ok
sql-mm-compoundcurve. ok
sql-mm-curvepoly. ok
sql-mm-general. ok
sql-mm-multicurve. ok
sql-mm-multisurface. ok
polyhedralsurface. ok
out_geometry. ok
out_geography. ok
in_gml. ok
in_kml. ok
iscollection. ok
regress_ogc. ok
regress_ogc_cover. ok
regress_ogc_prep. ok
regress_bdpoly. ok
regress_proj. ok
dump. ok
dumppoints. ok
wmsservers. ok
tickets. failed (diff expected obtained:
/tmp/pgis_reg_31671/test_47_diff)
remove_repeated_points. ok
split. ok
relatematch. ok
regress_buffer_params. ok
hausdorff. ok
clean. ok
sharedpaths. ok
snap. ok
Run tests: 55
Failed: 3
make[1]: *** [check] Error 3
make[1]: Leaving directory
`/home/postgres/software/postgis/postgis-2.0.0SVN/regress'
make: *** [check] Error 1
postgres at deb:~/software/postgis/postgis-2.0.0SVN$
also attach the logs from tmp
Regards,
Ticket URL: <http://trac.osgeo.org/postgis/ticket/735>
