[postgis-devel] [PostGIS] #735: regress failed
trac at osgeo.org
Tue Dec 28 23:00:16 PST 2010
Reporter: aperi2007 | Owner: pramsey
Type: defect | Status: reopened
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Resolution: | Keywords:
Comment(by nicklas):
Yes, strk, I did get stuck with the measures failure we discussed in #703
with 80 bit vs 64 bit, inside calculations vs variables.
I cannot understand why it doesn't get truncated to 64bit when I store it
in a variable and then uses it from there.
And why can 64 bit Linux and windows handle this but not 32 bit Linux?
Before we just camouflage this behind some rounding I would like to ask:
Is there anything special about this precision error. Isn't it likely that
we have this issue in many places?
Should I dig deeper in this to solve it, or is it just another precision
problem.
/Nicklas
Ticket URL: <https://trac.osgeo.org/postgis/ticket/735#comment:4>
